Guest Bill Fraser Posted November 29, 2021 Report Posted November 29, 2021 Which type of alarm should I install in a loft. The loft is only used for storage but has a gas boiler installed. Best regards, Bill Fraser Quote
green-foam Posted December 9, 2021 Report Posted December 9, 2021 I would suggest you install a carbon monoxide alarm in accordance with its instructions close to the boiler, and an optical smoke alarm in the loft as a minimum, better still use interlinked devices and have their counterparts on the landing, as you may not hear them if they are in the loft. Quote
