Guest Posted January 22, 2009 Report Posted January 22, 2009 I have an Ei 150 smoke alarm which has stopped working, is there an alarms which i can just fit onto the existing base? Quote
Garry Webster Posted January 22, 2009 Report Posted January 22, 2009 The unit that replaces the Ei150 is the Ei 151TL ionisation smoke alarm, this should fit directly onto your existing Ei150 base. The Ei15o and the Ei151TL are very similar units but the 151TL has 10 year rechargeable lithium cells. More information regarding the Ei 151TL Quote
