Morning,
I recently went to a property that has the old style flick test key sockets. They have 2 keyholes rather than the modern single key.
Does anyone know the type of key model I should get them to order to fit?
Thanks in advance.
Is it two test keys, check out the wiring and see if there is a manufacturers name on it or change for a modern test key, this will depend, if you are qualified, if not, get an electrician.
