Guest Mark Bonnington Posted September 14, 2021 Report Posted September 14, 2021 I know that smoke alarms need to be a min 300mm from walls, but is this the same for loft hatches does the alarm have to be a min 300mm from the hatch? Quote
green-foam Posted September 16, 2021 Report Posted September 16, 2021 The idea is that a smoke alarm is NOT mounted in a "dead area" If the loft hatch takes up most of the available room then you have no choice. Also you should read what the instructions say. Quote
