Guest Simon Posted August 14, 2021 Report Posted August 14, 2021 Hi there, I live in one of 5 flats in a large converted house. We don't currently have a fire detection system which has been highlighted in our fire risk assessment so I need to rectify this asap. I am hoping that someone would be kind enough to recommend products that would satisfy the following requirements: Grade A, interlinked - WIRELESS Common area (LD2 coverage): 4 x smoke detectors Inside each flat front door: Heat detectors (5 in total) Many thanks in advance... Simon. Quote
green-foam Posted August 14, 2021 Report Posted August 14, 2021 A grade "A fire alarm system" means it must have a separate control panel, this would require specialist knowledge to install/maintain, you should contact a couple of fire alarm companies near you and get two like for like quotes. Are you sure you must have a grade A wireless system? F.Y.I. You can have radio fire alarm devices that communicate with a main panel but they are very expensive, sometimes it is cheaper to have a wired grade A fire alarm installed. Quote
Tom Sutton Posted August 14, 2021 Report Posted August 14, 2021 I believe that would be satisfactory but you didn't mention a grade D LD3 should be provided in each flat by the freeholder however this is not subject to the RR(FS)O, according to the HOUSING – FIRE SAFETY Guidance on fire safety provisions for certain types of existing housing. Quote
AnthonyB Posted August 14, 2021 Report Posted August 14, 2021 Grade A Wirelesshttps://hyfirewireless.com/https://www.electrodetectors.co.uk/https://www.apollo-fire.co.uk/products/xpander/ https://eurofyre.co.uk/systems/wireless-fire-detection/ You can purchase from here https://www.safelincs.co.uk/wireless-fire-alarm-systems/ Quote
Guest Simon Posted August 17, 2021 Report Posted August 17, 2021 On 14/08/2021 at 16:51, Tom Sutton said: I believe that would be satisfactory but you didn't mention a grade D LD3 should be provided in each flat by the freeholder however this is not subject to the RR(FS)O, according to the HOUSING – FIRE SAFETY Guidance on fire safety provisions for certain types of existing housing. On 14/08/2021 at 14:43, green-foam said: A grade "A fire alarm system" means it must have a separate control panel, this would require specialist knowledge to install/maintain, you should contact a couple of fire alarm companies near you and get two like for like quotes. Are you sure you must have a grade A wireless system? F.Y.I. You can have radio fire alarm devices that communicate with a main panel but they are very expensive, sometimes it is cheaper to have a wired grade A fire alarm installed. This is the word for word specification in our FRA: As per LACoRS Guidance 2008 we would recommend a Grade A: LD2 coverage in common areas, and a heat detector in each flat in the room / lobby opening onto the escape route (interlinked). We've contacted several companies but few respond and the ones that do have quoted £6k-£8k. We are owner occupiers and don't have that much money, so are exploring all of our options to be able to satisfy the FRA specification, while minimising the cost. Quote
Guest Simon Posted August 17, 2021 Report Posted August 17, 2021 On 14/08/2021 at 20:34, AnthonyB said: Grade A Wirelesshttps://hyfirewireless.com/https://www.electrodetectors.co.uk/https://www.apollo-fire.co.uk/products/xpander/ https://eurofyre.co.uk/systems/wireless-fire-detection/ You can purchase from here https://www.safelincs.co.uk/wireless-fire-alarm-systems/ Many thanks - I will check these out. Quote
