Guest Guest Posted August 13, 2021 Report Posted August 13, 2021 Hi, We have some steel fire doors in my building which have had mag locks repositioned & taken away which have left holes in the doors. Can these doors be repaired or is a new door set required? Also one set of steel fire doors has the top half resting on the doorstop but the bottom half of the door is sitting away from the stop, which looks twisted. Will these need to be replaced? Quote
Neil ashdown Posted August 14, 2021 Report Posted August 14, 2021 I would certainly have the doors repaired, if not replaced. But for advice contact the door manufacturer. Otherwise contact the Door & Hardware Federation to find a competent maintenance & repairs company metal fire doors. Quote
