Guest peter fry Posted August 11, 2021 Report Posted August 11, 2021 Do you have to be certified to fit fire dampers within ventilation systems if you follow the manufacturers installation guidance. Quote
AnthonyB Posted August 11, 2021 Report Posted August 11, 2021 Technically no, but it is strongly recommended as often (not always to be fair) non approved installations are sometimes not correct. However if you feel you are competent to a legally defensible level then it's fine. Quote
