contractman Posted August 3, 2021 Report Posted August 3, 2021 Hi I have recently come across a protected staircase, which the school has recently lined with carpet (they are unaware if its fire retardant) I am aware that protected staircase, should be of a fire resisting construction but obviously have concerns on the floor covering. I have looked in BS9999 and ADB, but cant see anything relating to floor coverings in a protected staircase Appreciate any it if anyone could advise or detail any relevant details I can quote Thank you Quote
Tom Sutton Posted August 6, 2021 Report Posted August 6, 2021 What do you mean lined is the carpet fitted to the floor or the walls. Quote
Tom Sutton Posted August 9, 2021 Report Posted August 9, 2021 I my experience non FR carpet fix to the floor is not a serious fire risk it can be more a tripping hazard but you should ensure it doesn't pass under fire doors in case it passes fire under the fire door, consequently not provide the necessary protection. Quote
contractman Posted August 10, 2021 Author Report Posted August 10, 2021 9 hours ago, Tom Sutton said: I my experience non FR carpet fix to the floor is not a serious fire risk it can be more a tripping hazard but you should ensure it doesn't pass under fire doors in case it passes fire under the fire door, consequently not provide the necessary protection. Thank you Quote
