Guest gertrudtrad Posted January 27, 2012 Report Posted January 27, 2012 hi my Ei146 sits on a radio base and the radio base flashes an amber light every 10 seconds. All other smoke alarms in the group are fine. Can anybody help? Gertrud Quote
Safelincs Posted January 27, 2012 Report Posted January 27, 2012 Hi Gertrud The amber light indicates that the rechargeable backup battery of the radio-base (Ei168) is running low or not re-charging properly. First thing to check is that the internal 'Battery on' switch is properly triggered. Remove the smoke alarm with the help of a screw driver and press the 'on' switch on the base plate. (see picture of switch in manual) If that does not resolve the issue, check that the power supply is not switched. This can happen if the wiring coming from the nearest light fitting to the alarm has been installed incorrectly. Switch the light, from which the smoke alarm is fed with power, on and leave it on for 24 hours; if the amber light stops, call out the elctrician to check wiring. If the amber light continues, it could be a battery damage. In this case contact your retailer. Harry Quote
Tom Sutton Posted January 27, 2012 Report Posted January 27, 2012 Harry do you know of a self contained, radio linked, smoke alarm? Quote
Safelincs Posted January 27, 2012 Report Posted January 27, 2012 Hi Tom Yes, there are battery operated, radio-interlinked alamrs: 1) Ei3100RF smoke and heat alarms with alkaline battery 2) Ei600RF smoke and heat alarms with sealed-in 10 year lithium battery the second style is commonly accepted by Building Inspectors or fire safety specialists as a BS5839 part 6 grade D replacement Harry Quote
Guest Fire alarm Posted September 24, 2016 Report Posted September 24, 2016 I cant stop my alarm beeping every 30seconds ish please help shut it up thanks fiona Quote
Safelincs Posted September 26, 2016 Report Posted September 26, 2016 Hi The first step is to take the alarm down. Please see our range of videos showing you how to remove the various smoke alarm models. Check that the alarm is no older than 10 years, as it would need replacing in that case. If the battery can be removed, please replace battery. When taking the alarm down and the battery out, did the beeping stopped? The beeping may be down to another device in the property. We would recommend checking if you have an old battery smoke alarm or a CO alarm in the property that may be the cause of the beeping. Also check the Wiring as there may be a loose connection. You will need to consult an Electrician in your area Harry Quote
