One of my colleagues has pointed out that perko style concealed door self-closers are now non compliant.  I have looked at ADB volume 1 (2019 edition with 2020 ammendments) as I am dealing with blocks of flats & sheltered housing with flats opening onto escape routes.  I could not find anything in there to say that they were not now unnaceptable, or if they should be removed retrospectively.
I understand new builds having overhead closers, but should I be advising that Perko style closers be fitted retrospectively to buildings that had these doors fitted following guidance from the time they were built?  I am writing up an FRA at the moment for a 1988 built sheltered scheme and the suggestion is I should be asking for all doors to flats to be fitted with overhead closers and disengaging the concealed closers.
If this is the case, is there any guidance or legislation I can quote to bolster the argument?  I did not recommend this in the first draft of my FRA, but mu colleague has suggested I add this in.
Any help greatly appreciated!
  • 2 weeks later...
ADB is a design guide not a risk assessment guide for existing premises. Risk assessment guidance contains what you are looking for regarding Perkos
For flats use:
https://www.gov.uk/government/publications/fire-safety-in-purpose-built-blocks-of-flats
For sheltered housing use:
https://www.nationalfirechiefs.org.uk/write/MediaUploads/NFCC Guidance publications/NFCC_Specialised_Housing_Guidance_-_Copy.pdf
