Guest AngeloTak Posted January 26, 2012 Report Share Posted January 26, 2012 I have been told by a manufacturer tha to use a timber veneer type product as the facing material on any fire door then the maximum approved thickness cannot be greater than 2.0mm. Is this correct and if so where can I find the regulations associated with facing materials Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted January 26, 2012 Report Share Posted January 26, 2012 You should get in touch with The British Woodworking Federation or BMTRADA they should be able to answer that one. Quote Link to comment Share on other sites More sharing options...
