Guest JohnStei
I am chairman of our residents association and we run the block ourselves. The block is 40 years old and purpose built - comprising 12 flats.
Is it a legal requirement that emergency lighting should be installed in the common parts of the building?
Thank you
The description states "The block is 40 years old and purpose built - comprising 12 flats" consequently it is unlikely to be a HMO/Shared house more likely to be self contained flats therefore only the RR(FS)O will apply.
Hi Tom
You might be right about self-contained flats. In this case it depends on the number of floors. The LACoRS guide asks for emergency lighting for self-contained flats from five floors upwards.
Hi Harry
I have looked through the guide and cannot find any references to purpose built self-contained only converted self-contained and there is a subtle difference.
Guest Ryan Mcmullan
Hi
Just to inform you, you may wish to take a look at Fire safety in purpose built flats which is more current and relevant, it also takes into consideration the guidance in the LACORS manual and works along side it.
