When replacing the lock cylinder, to a timber-based fire resisting door, ensure that the new cylinder is suitably fire rated and that the mortice work around the cylinder is tight with no gaps. If it isn't, repair with timber/rock wool/intumescent mastic as necessary.
There is no legal requirement to obtain certification particular to this this work.
OTHER BRANDS ARE AVAILABLE
Guest Bradley Hughes
Thanks Tom and Neil.
New install was carried out under BMq TRada. But as now void locks change was required. I have changed this out before, and I believe a renew cert under FDIS is not needed as long as operative replaces like for like.
