Guest JK1 Posted May 27, 2021 Report Posted May 27, 2021 If fire door glazing does not have a fire rated glass stamp, I guess the only way to tell if it is fire rated is to check with the manufacturer from the BWF label as to what the door should have in it for the rating it is the ask a certified FR glazing contractor, or you may find some information in the building file? Does FR glazing have to have a stamp? Quote
AnthonyB Posted May 28, 2021 Report Posted May 28, 2021 Yes if installed correctly. No stamp, no good. The same applies in Health & Safety for glazing that, due to location, has to be toughened or laminated against impact, no mark, no good. Quote
Guest Oli Posted July 18, 2023 Report Posted July 18, 2023 Does this apply to Georgian Wire Glass aswell - or is it safe to assume GWG is at least 30 min rated without any markings whatsoever? Thanks Quote
Neil Ashdown MAFDI Posted July 20, 2023 Report Posted July 20, 2023 https://www.ggf.org.uk/publications/fire-resistant-glazing-publications/guide-best-practice-specification-use-fire-resistant-glazed-systems/ Quote
Guest Oli Posted July 26, 2023 Report Posted July 26, 2023 Thanks for that information, but I struggle to see an answer. We have plenty of older doors with wired glass in them but no markings. As i say, is it common sense to assume they are 30 min fire rated minimum because they are Georgian wired glass. Quote
Neil Ashdown MAFDI Posted July 27, 2023 Report Posted July 27, 2023 This might help http://firstglass.ie/wp-content/uploads/2019/03/Pilkington-Pyroshield-Pyroshield-2-Comparison.pdf Wired glass has traditionally been cut from larger sheets (thus no marking) and used for glazing of fire doors and screens where fire protection is required. The glass will crack in a fire but its fire rating is provided by the wire holding the glass together and this type of glass can be found widely in timber fire doors and glazed screens. In recent years the products have been improved - see Pyroshield 2 (above link) and Pyrostem https://www.pyroguard.eu/all-products/pyrostem/ The GGF guide provides best practice guidance for selecting products and installing them where 'fire rated glazing systems' are required. Quote
Matt 12345 Posted April 30, 2024 Report Posted April 30, 2024 Hi all, We have been provide some door surveys by others to price the remedial works. The surveyor has noted that multiple doors have glass in the leafs with no stamp and there are no o&m's or testing for the doors. They are 44mm leafs with intumescent strips, fire rated hinges etc... but the remedial advice is to change the glass. Is this acceptable if we do not have the testing to know what glass type should be used??? TIA Quote
AnthonyB Posted May 1, 2024 Report Posted May 1, 2024 If it doesn't have the etching for fire rated glass as oppose to just toughened or laminated the assumption has to be it isn't - fire rated glass in the pre-etching days was almost universally Georgian wired so if it was clear it wasn't fire glazing. I'd have no option to request the glass is changed myself. Quote
