Mosh Posted May 7, 2021 Report Posted May 7, 2021 Does an electronic rim lock (on a front door) automatically fail to safety? Does it need to be tested / serviced as part of a fire plan? Quote
green-foam Posted May 7, 2021 Report Posted May 7, 2021 All the ones I have seen you have to press the red button which energises a coil which allows you to open the door, so that means they are fail secure. Quote
AnthonyB Posted May 7, 2021 Report Posted May 7, 2021 Looks electro-mechanical and not usually allowed on exits, absolutely not if not failsafe. Depending on the type of override if it was fail safe there are maintenance/testing obligations Quote
Mosh Posted May 9, 2021 Author Report Posted May 9, 2021 Thanks for your replies. I guess i'll have to find out more details about it. Quote
