Hannah Posted April 28, 2021 Report Posted April 28, 2021 Hi, If there is a scenario where a residential and commercial tenants fire route leads to the back of the building into a courtyard of approx. 10m long. However the door from that courtyard requires a key to get to the final place of safety, i.e. as far away from the building as possible. What would be a suitable measure to ensure this route away from the property is accessible for both tenants.? Considering secure push bar, thinking a key box would not be sufficient? Thank you. Quote
AnthonyB Posted April 28, 2021 Report Posted April 28, 2021 Any current type of simple fastening not requiring a key would suit, BS EN 1125 panic fastenings would only be needed if over 60 persons would be using the route or would be unfamiliar with it - BS EN 179 exit devices may suffice. Quote
Hannah Posted April 29, 2021 Author Report Posted April 29, 2021 Hello, thank you so much for the reply. That is really helpful. Quote
