Guest John Posted July 1, 2011 Report Posted July 1, 2011 I recently had to use the fire blanket in my kitchen, can I replace just the blanket part or do I need a whole new unit with a case again? Quote
Garry Webster Posted July 1, 2011 Report Posted July 1, 2011 I recently had to use the fire blanket in my kitchen, can I replace just the blanket part or do I need a whole new unit with a case again? If you can find a company that sells just the blanket in the right size and standard you could of course keep the casing. Just make sure you clearly mark the 'refill' on the maintenance sticker on the casing. However, new fire blankets are so cheap these days that this is probably not worth the effort. Quote
