Guest John P Posted March 12, 2021 Report Posted March 12, 2021 I live as owner occupier (long leaseholder) in a managed block of flats. The block has a communal fire alarm system with sounders in the flats and the communal areas. I want to fit an ADO to my flat entrance door (which is a fire door) for disability purposes. (I am wheelchair dependent for my mobility). The ADO installation includes a 48hr battery back up in case of mains power failure. Is it a requirement that the ADO is connected to the communal fire alarm system? As I understand it, this would simply "convert" the door to normal manual operation when the fire alarm sounds. Quote
