Mr
THERE IS A ENTRANCE/EXIR DOOR 1MTR WIDE FOR DISABILITY ACCESS, HOWEVER IT WOULD OBVIOUSLY BE USED AS A FIRE EXIT SHOULD THERE EVER BE A FIRE.
THERE IS A RAILING 1 MTR FROM THE DOOR SWING IN FRONT OF THE DOOR, IS THIS LEGAL
Can you still open the door 90 degrees + to give the full unobstructed width and then move away to safety along a route that is also 1m? (Even if you have to immediately turn left or right because of the barrier)
Who would be using the route?
