Meady Posted February 11, 2021 Report Posted February 11, 2021 We manage a few properties on behalf of a landlord - this query relates to a commercial property occupied by a single tenant for Office purposes. The tenant occupies 100% of the building. No shared or sub-let parts. As there are no common areas, does the Landlord need to arrange a FRA for anything, or should the tenant be responsible for this entirely? Quote
AnthonyB Posted February 11, 2021 Report Posted February 11, 2021 No, all completely down to the tenant. It's similar with typical small buildings with a retail unit on ground and a floor or two of offices above with a single lease each for the whole of the office (including its stair) and a single lease for the unit. Often the whole building fire alarm is in one demise off it's board and some agents assume that because there is one system 'common' to the premises they need to maintain it (even when the lease assigns no such responsibility to the landlord/freeholder) and carry out an FRA and then when actions are required (as these systems are often quite old) complain as there is no service charge to pay for it and the client has to stump the cost - precisely because the system isn't common at all! In these cases the tenant who has the panel & it's power supply is responsible for it through the whole building and they and the other leaseholder have to work together to manage fire safety as per Article 22 of the Fire Safety Order Quote
Meady Posted February 12, 2021 Author Report Posted February 12, 2021 19 hours ago, AnthonyB said: No, all completely down to the tenant. It's similar with typical small buildings with a retail unit on ground and a floor or two of offices above with a single lease each for the whole of the office (including its stair) and a single lease for the unit. Often the whole building fire alarm is in one demise off it's board and some agents assume that because there is one system 'common' to the premises they need to maintain it (even when the lease assigns no such responsibility to the landlord/freeholder) and carry out an FRA and then when actions are required (as these systems are often quite old) complain as there is no service charge to pay for it and the client has to stump the cost - precisely because the system isn't common at all! In these cases the tenant who has the panel & it's power supply is responsible for it through the whole building and they and the other leaseholder have to work together to manage fire safety as per Article 22 of the Fire Safety Order Thank you again AnthonyB - always much appreciated. Quote
