pyrolysis Posted January 27, 2021 Report Posted January 27, 2021 Hi. Hopefully someone can give their thoughts on the following scenario: What is the maximum travel distance from a flat on the 3rd floor of a 4 storey building. The only route to exit the upper floor flat is via an open air walkway to a protected stairwell. This is also the normal means of entry/exit to this flat. I have measured the current travel distance and it is 21 meters (Flat door to the protected stairwell). Quote
Tom Sutton Posted February 1, 2021 Report Posted February 1, 2021 Check out section 59 of Fire safety in purpose-built blocks of flats. Quote
