Guest Lynn Mackay
I am the building manager of a residential property. We have recently installed a new fire panel that has a direct link to the fire brigade. Should the fire services arrive out of hours they will have no access to the fire panel key, we have a locked box by the panel. Is it acceptable to have a ‘break glass for key’ unit with the key for the box?
thanks
The issue you will have is that should the FRS attend they cannot reset the alarm (assuming it’s a false alarm) due to litigation reasons. They will only investigate the origin of the alarm actuation. So a key holder(s) should be appointed and their contact information held by the alarm receiving centre. They then are duly contacted to reset the alarm.
