NICHOLAS Posted January 14, 2021 Report Posted January 14, 2021 Evening All, I have been handed a job to route out a riser cupboard door and fit a intumescent brush seal, however there is an intumescent seal built into the frame. I was led to believe when I did my fire door training that you cannot have both. Is this correct or should I just remove seal in the frame and replace with intumescent brush seal. Look forward to replies. Quote
AnthonyB Posted January 15, 2021 Report Posted January 15, 2021 Either remove and replace or use a separate surface mounted smoke seal, the former being preferred. Quote
Neil ashdown Posted January 18, 2021 Report Posted January 18, 2021 On a single leaf door, you should not fit intumescent seals to the door leaf edge where one is already fitted to the door frame. Image below seal shows options. Quote
