Hi, I recently took over the maintenance of an accommodation building and have found 3 maintained bulkhead emergency lights on which they operate as normal lights, the green LED is on, but when I do a test they don't light up.  Help/advice would be appreciated.
Sounds like the battery packs have failed as from your description the bulbs are OK and the mains into the charger is OK too.
You can buy replacement battery packs which is easier than replacing the whole fitting
