I live in a block of flats which has 3 main entrances at the front of the building. There are 2 corridors on the ground floor which lead to reception areas and I live at the end of one of these corridors. At either end of the corridor, there are fire doors and to change the flow of walking traffic late at night I am in discussions with the managing agent of my block to see if any solution can be found.
Would it be possible to fix keypads with emergency exit latches a bit like the below in that sort of arrangement?
https://www.safelincs.co.uk/exidor-297-single-door-push-pad/?sku=EXD297CL1&fGB=true&gclid=EAIaIQobChMI0azF_ueg7QIViOmyCh3LZABuEAQYASABEgLPx_D_BwE
Both fire doors lead to the reception areas where the external exits are located.
Thanks in advance!
