Re-location of emergency door
Guest ABU AMNA
In our Furnace control room of glass manufacturing company which is constructed over a gas station, there is an emergency door leading to the gas station side rather than outside of the plant in open area or in walkway.As there is no sufficient space AROUND to relocate it.One of our 3rd party auditor raised this objection but we have problem that due to unavailability of space we can not re-locate this emergency door so what is the solution and how we can satisfy our certifying body.
I need suggestion for the solution of said above point.
To give you a well reasoned answer you would need a lot more information including a full survey or detailed plans of yours and the gas station also what do you mean by gas station.
