Guest rib Posted October 21, 2020 Report Posted October 21, 2020 I live in a rental property and have Ei Optical Smoke Alarms installed in each room - not sure which model but our manual covers the Ei3024/3016/3014. The RF Module LED indicator on one of the alarms is flashing red twice quickly at 3/4-second intervals, with no sound coming from it. We've looked at the manual and can't see any answers there - all other alarm units are as normal, with a solid green light. Does anyone know what the problem could be? Quote
Guest Adam Posted December 31, 2021 Report Posted December 31, 2021 Same problem here. The manual states NOTHING about the red light flashing twice every couple of seconds! Why have an error code and then not explain what it means or how to clear it?? Quote
green-foam Posted January 6, 2022 Report Posted January 6, 2022 Which model do you have and what is flashing? (The detector or the RF module) Quote
Guest Magda Posted February 11, 2022 Report Posted February 11, 2022 Mains Powered Smoke Alarms & Heat Alarms with Self-Charging 10 Year Back-up Battery - Aico Ei3000 Series Same problem and is the rf module flashing Quote
Guest Magda Posted February 15, 2022 Report Posted February 15, 2022 On 21/10/2020 at 22:13, Guest rib said: I live in a rental property and have Ei Optical Smoke Alarms installed in each room - not sure which model but our manual covers the Ei3024/3016/3014. The RF Module LED indicator on one of the alarms is flashing red twice quickly at 3/4-second intervals, with no sound coming from it. We've looked at the manual and can't see any answers there - all other alarm units are as normal, with a solid green light. Does anyone know what the problem could be? As above Quote
green-foam Posted February 21, 2022 Report Posted February 21, 2022 Press and hold the test button for 30 seconds Quote
Guest JCo Posted September 21, 2022 Report Posted September 21, 2022 I had the same issue and tried this and it didn’t work, is there something else to try? Quote
green-foam Posted September 26, 2022 Report Posted September 26, 2022 What exactly is happening in your situation, and what is the make and model of your smoke alarm and how old is it, and when did you last change its battery? Quote
Guest Guest23 Posted October 9, 2022 Report Posted October 9, 2022 On 21/10/2020 at 22:13, Guest rib said: I live in a rental property and have Ei Optical Smoke Alarms installed in each room - not sure which model but our manual covers the Ei3024/3016/3014. The RF Module LED indicator on one of the alarms is flashing red twice quickly at 3/4-second intervals, with no sound coming from it. We've looked at the manual and can't see any answers there - all other alarm units are as normal, with a solid green light. Does anyone know what the problem could be? Did you ever find a fix for this? We currently have the same issue. Cannot find any info on it in the instruction manual. Quote
green-foam Posted October 10, 2022 Report Posted October 10, 2022 18 hours ago, Guest Guest23 said: Did you ever find a fix for this? Please do not ask other posters a question, the reason being that they will often post a question and never be heard from again, the poster you are "asking" posted 2 years ago, never to be heard from again. Several questions for you. What is the make / model of your smoke alarm? How old is it? When did you last change its battery? When did you last clean it? Does it work when you press the test button? Have you had ANY electrical work carried out in the last 2 months? I ask these questions as I am not there, so I do not know the answers. Sometimes people assume that all the smoke alarms they have are all the same, they should be but sometimes they are not, that is why I ask you to check the make and model. Quote
