Hyperion Posted September 20, 2020 Report Posted September 20, 2020 Would a linked passage way between two properties which has glazing, need to be fire rated? The passage link windows/glazing is to the open. So I can’t see why it need to be? thanks Quote
AnthonyB Posted September 21, 2020 Report Posted September 21, 2020 How wide is it? There could be issues with fire spread between buildings and the ability to navigate the external exit route. Quote
Hyperion Posted September 21, 2020 Author Report Posted September 21, 2020 Approx 1.5m wide. There are two fire doors at either end with glazing along the link corridor. Quote
Tom Sutton Posted September 23, 2020 Report Posted September 23, 2020 It will most likely not be required but as AB has said there could be issues that may require the glazing to be uprated, like a narrow external escape route for instance. Quote
