James Gormley Posted September 12, 2020 Report Posted September 12, 2020 We are carrying out work to bring firedoors up to standard, following a FRA, many of the hinges in this 10 year old apartment block have oil leaking from the hinges, mostly on corridor doors heavily used. Should we be changing these or are they okay ? Quote
AnthonyB Posted September 16, 2020 Report Posted September 16, 2020 It's a sign of wear, particularly if there are flakes of metal in the oil, and most fire door inspectors will 'fail' the door and require renewal. If the doors are still functioning properly then the risk is less and it's more of a warning sign, but the door would need more regular ongoing checking to ensure the hinges haven't totally gone. Quote
James Gormley Posted September 22, 2020 Author Report Posted September 22, 2020 Very helpful, Thank You. One more thing, when adjusting doors to achieve the 3mm gap on an fd30 door, 10 years old, that has no intumisent hinge packers should we be removing the door and the 3 hinges, removing extra material from the frame and door recesses to allow for the thickness of the hinge packers, refix the hinges to the door, Then rehang the door . Or can we put an odd hinge packer behind hinges on frame side to adjust the door. Thanks Quote
Tom Sutton Posted September 23, 2020 Report Posted September 23, 2020 Questions about fire doors are best asked on on Fire Doors and Accessories as this is the area that Neil Ashdown inhabits, and he is good. Quote
