Escape through kitchen window
My daughter has moved into a student house with four bedrooms.  Her ground floor room is accessed through the kitchen and she has a door to the garden, but it will not open.  The landlord is not willing to repair the door and says her escape route in case of a fire in the kitchen is through the window in her bedroom.  Is this an acceptable fire escape or can she insist that the door is repaired?
Doesn't sound acceptable. She shouldn't have to escape through a high risk room, unless she can enter a protected corridor/area to avoid the kitchen and make her way to an alternative exit (which has to be within the recommended travel distance of 18m /35m depending on numbers of exits).
Her window would merely facilitate escape in the event of fire blocking her escape via the door to the garden.
This does conform to ADB vol 1, but assumes you have either a door or an escape window, because in theory it meets the requirement it could be considered satisfactory but I would dispute it and contact an enforcement office of the local fire and rescue service and get his opinion.
Check out Approved Document B (Fire Safety) Vol 1
