Guest Daisy Posted August 13, 2020 Report Posted August 13, 2020 I currently rent my house and have some doors that do not close fully, they can be pushed shut but do not have the click. Another door closes but not fully as it seems to big for the frame. Are these in line with the fire safety regulations? The back and front door are fire safe. The house is rented out via an estate agent and they have inspected it and did not say it was a problem and passed inspection for it to be rented out. The house is old and if the doors need replacing then the door frames will need replacing too? Quote
Tom Sutton Posted August 21, 2020 Report Posted August 21, 2020 The internal doors in a domestic dwelling should meet a FD20 standard and a substantial standard door without intumescent strips,self closers, should meet that standard but if a door doesn't close fully then it meets no standard. In a flat any door to the common area should meet a FD30s standard. Quote
Guest Jules Posted November 16, 2021 Report Posted November 16, 2021 Council E.H.Officer.Quotesd the housing act 2004 saying all doors should be solid doors not hollow. Building control said they should be fire doors or non fire doors of any description. Who's right Quote
AnthonyB Posted November 18, 2021 Report Posted November 18, 2021 If it's an existing legacy build then well fitting solid doors are usually accepted under the Housing Health and Safety Rating System for the purposes of the Housing Act. If a new build or an extension/renovation coming under the Building Regulations is being carried out then internal doors have to be FD20 doors (in practice FD30 get fitted) or FD30 between a garage & house if attached. If no relevant Building Work has been carried out it isn't under the jurisdiction of Building Control so go with the EHO. Quote
Guest Fiona McDonaugh Posted November 10, 2024 Report Posted November 10, 2024 We have a rental property with 4 bedrooms. After a recent Council inspection we have been told to supply a fire door to the kitchen and solid doors to the bedrooms. The carpenter we approached to do the work insists we have to have fire doors throughout, is this true? Quote
AnthonyB Posted November 11, 2024 Report Posted November 11, 2024 On 10/11/2024 at 12:59, Guest Fiona McDonaugh said: We have a rental property with 4 bedrooms. After a recent Council inspection we have been told to supply a fire door to the kitchen and solid doors to the bedrooms. The carpenter we approached to do the work insists we have to have fire doors throughout, is this true? As the Council are the enforcement body then if they are happy with good fitting solid doors to bedrooms and only a fire door to the kitchen then that's all you need to do - this sounds like a Housing Act HHSRS issue so different guidance applies compared to if you were carrying out work under Building Regulations Quote
