Guest RobertF Posted August 5, 2020 Report Posted August 5, 2020 I would welcome your thoughts on the following scenario I've recently been asked to look at an issue in a care home whereby a risk has been identified concerning residents with dementia being able to traverse the staircases (which serve as primary access and egress for staff and evacuation). At each level the 2nr stair and lift lobbies connect either side of the care home and is required as a throughfare to allow residents to access facilities etc at either sides. Due to the structural layout it is not feasible to enclose the stairs further with say fire doors directly at the head and feet. The simplest solution would be similar to a child gate at the head and the foot of each. I'm assuming that this could compromise evacuation in the event of fire therefore a hybrid/bespoke solution with mag lock linked to fire alarm may suffice. Does such a product exist and does anyone have any experience of this scenario? Many thanks Quote
Tom Sutton Posted August 17, 2020 Report Posted August 17, 2020 I have never heard of such a product but my experiences of a least one dementia care home, is the staff accompany all residents, except when they are in the day room, dining room or own bedroom, so is such devices needed. Quote
Guest RobertF Posted August 21, 2020 Report Posted August 21, 2020 Thank you Tom Yes it would seem that the day room facilities are either side of the staircase/lift lobbies and residents are free to move between unsupervised. Kind regards Quote
Tom Sutton Posted November 11, 2020 Report Posted November 11, 2020 The only answer I can envisage is that resident will have to be supervised when passing through the staircase enclosure. Quote
