Guest Manuel Posted June 24, 2020 Report Posted June 24, 2020 hi, we have a 3 storey home, and we´d like an efficient solution, at the same time affordable, larger extinguisher units aren´t cheap,the house is aprroximately 660 sq foot big, with a garage, my idea would be the following: -2kg carbon dioxide near entrance and 3 litre multichem abf foam for kirchen on ground floor 3l foam for the upper floor. for the garage a 2kg abc dry powder, as it is cheap affordable and quite powerful, im afraid is quite small and probably better going for a 4 kg Please i would be really thankful receiving advice and opinions. Quote
AnthonyB Posted June 24, 2020 Report Posted June 24, 2020 To be fair any domestic fire small enough to be safely tackled by an untrained occupier would be within the capabilities of a 1.4L Water Mist extinguisher, one per landing (3l if you really want, but costly) If you can't put a garage fire out with 2kg Powder you should be leaving it to the brigade. A 3l foam would be similar performance but cleaner and easier to see. All are available from the forum sponsor Safelincs. Quote
green-foam Posted June 24, 2020 Report Posted June 24, 2020 The forum owners (Safelincs) fire extinguisher page can be found if you Click here Quote
