Guest garrydarl Posted January 4, 2012 Report Posted January 4, 2012 Hi I would like to use a fire escape ladder from a second floor bedroom window. There is a window on the floor just underneath. Will this not break when I climb down? Has anybody used a ladder in the same situation? Thanks Garry Quote
Safelincs Posted January 4, 2012 Report Posted January 4, 2012 Hi Garry You are of course right, the rungs or their standoffs will push against the window. I have tried a few of the ladders in a similar situation myself and the rungs did not cause the glass of the windows to break. If you are very concerned about this you could choose a semi-rigid fire escape ladder where the ladder does not sway as much and the rungs will not press against the window. Harry Quote
