nwpattesting Posted April 27, 2020 Report Posted April 27, 2020 Hi, I am in the process of arranging for my fire doors to be upgtaded. The joiner who does a lot of these told me the max 4mm gap is not possible as the door wouldnt close properly with the intumescent strips fitted. Is that correct ? Thanks Quote
AnthonyB Posted April 27, 2020 Report Posted April 27, 2020 No, not if fitted properly - this is why a competent fire door contractor should be carrying out these works, I've seen thousands of pounds of wasted work on doors by well meaning joiners. Quote
nwpattesting Posted April 27, 2020 Author Report Posted April 27, 2020 Thanks for that, Im trying to work out, how thick is the intumescent/ smoke strip ? does the thickness vary as to whether its a self adhesive one that fits in the frame or a routered one in the door ? thanks Quote
Neil ashdown Posted April 28, 2020 Report Posted April 28, 2020 There are various types of smoke seal including types that are separate from the intumescent strip. https://www.lorientuk.com/products/architectural-seals/perimeter-seals So the 4mm maximum gap should not be an issue at all and make sure your fire door upgrading contractor has the necessary competence !! Quote
