Guest Adrian Posted March 2, 2020 Report Posted March 2, 2020 I am installing audio system in a basement of a commercial premises. I had planned to use the LSZH cable because I figured if it is safer then why not. However, on receiving the cable I have found that it is significantly more rigid than conventional PVC cable and will consequently have a noticeable negative affect on our acoustic plan which is the main reason I have been employed to do this. I am mounting most of the cable in standard plastic trunking. Am I right in thinking that if the cable is in plastic trunking the amount of smoke generated by the trunking will out weigh any improvement in visibility/toxicity provided by the LSZH cable. The basement is not huge, we are talking about a gym for about 36 people to train in at a time. Many Thanks Quote
Tom Sutton Posted March 6, 2020 Report Posted March 6, 2020 Are you using any fire safety guidance in your proposals or is it just your own ideas? Quote
