Guest PH88 Posted February 21, 2020 Report Posted February 21, 2020 Hi, recently visited a HMO which had a bolted stair gates at the top and bottom of the stairs. There is only one staircase which acts as the means of escape for the four flats on the first floor. Anyone else come across this before? My view is that they should be removed as they are compromising the means of escape in the event of an emergency. Thank you. Quote
Tom Sutton Posted February 22, 2020 Report Posted February 22, 2020 I would find out why there are bolted stair gates at the top and bottom of the stairs as young children shouldn't be allowed by themselves in the common areas, but there may be other reasons. Quote
Guest Usha Vara Posted June 17, 2020 Report Posted June 17, 2020 On 21/02/2020 at 15:30, Guest PH88 said: Hi, recently visited a HMO which had a bolted stair gates at the top and bottom of the stairs. There is only one staircase which acts as the means of escape for the four flats on the first floor. Anyone else come across this before? My view is that they should be removed as they are compromising the means of escape in the event of an emergency. Thank you. I agree - I have been asked whether the HMO we look after can have stair gates, I dont think they should as its a fire exit in an emergency and its a common area? Anyone else have any other views? Quote
Tom Sutton Posted June 22, 2020 Report Posted June 22, 2020 I would agree it is an escape route and stair gates would be an obstruction. Quote
