Hi, I have a house converted into small flats, it’s a 3 storey building.
it already has mains heat and smoke detectors, but should it also have a control panel ? If so is there a certain spec it would need to be ?
also would it need call points ?(break glass) ?
if it makes any difference the communal area is only 2 storeys of stairs, with the top flat having its own private stairs.
thanks
