Guest Dan Posted January 29, 2020 Report Posted January 29, 2020 I’ve an early 1900s 3 storey holiday let, it has 4 bedrooms which occupy the 2/3rd floors it has one stairwell, travel distance is 16mtrs to exit from furthest bedroom , it has a D LD2 fire alarm system, I’m wondering whether I need FD30s fire doors to protect the escape route or solid timber doors with closers would be sufficient Quote
Tom Sutton Posted February 1, 2020 Report Posted February 1, 2020 I would use https://www.gov.uk/government/publications/fire-safety-risk-assessment-sleeping-accommodation which suggests 9 metres for single means of escape so in that case you will need all doors leading on the the stairwell must be FD30 fire doors. An interlinked group D domestic fire alarm should be acceptable. Quote
AnthonyB Posted February 1, 2020 Report Posted February 1, 2020 If your let is no bigger than a typical family house and does not have a complex layout you may be able to use this alternative guidance which may allow your current layout: https://www.gov.uk/government/publications/do-you-have-paying-guests Quote
