Mike O'Flaherty Posted January 27, 2020 Report Posted January 27, 2020 I had some FD30S fire doors fitted in a block of flats complete with a FIRAS installation certificate in 2017; however, when I inspected the doors I could not see the smoke seal, only what looked like a draft excluder around the frame. I questioned this with the manufacturer, and they said the Aquamac 21 weather seals were the smoke seal. I have asked for the data sheet, but does anyone know if a weather seal is essentially the same as a smoke seal? I can't see any reference to Aquamac 21 having BS 476 31.1 testing. Thanks, Mike Quote
AnthonyB Posted January 28, 2020 Report Posted January 28, 2020 It's possible, several smoke seals are advertised as combined acoustic, draught & smoke seals - they are only to stop cold smoke prior to the activation of the intumescent seal. Quote
Neil ashdown Posted January 29, 2020 Report Posted January 29, 2020 Composite construction fire doors for the flat entrance (timber doors a little less often) often use a cold smoke seal that performs more than one function. The person responsible for procurement of the fire doors and the installation works should satisfy themselves that the smoke sealing performance for the door-set is confirmed by suitable documentary evidence of performance to BS 476 part 31.1 / BS EN 1634-3. Quote
