Tom Sutton Posted March 13, 2019 Report Posted March 13, 2019 Providing not to much needs to be removed from the corner of the door you should be alright. Quote
Guest Steve Posted March 22, 2019 Report Posted March 22, 2019 Hi, I just wondered if the door has to be a slam shut lock, or whether you can have a lever handle, which wouldn't lock when the door is shut? Many thanks Quote
Neil Ashdown MAFDI Posted March 27, 2019 Report Posted March 27, 2019 The door should be fitted with a suitable self-closing device and latch.They must both be compatible with the fire door leaf. The door must self-close to the stop of the door frame rebate overcoming resistance from the latch bolt and smoke seals so that the door leaf 'self-latches' into the keep at the door frame. A lock is optional, but clearly desirable for security purposes. Quote
Guest A Haines Posted June 6, 2019 Report Posted June 6, 2019 Hello, what are the current requirements for a new attached garage (to be built in single skin blockwork) with a new pitched slate roof? There would be 2 fixed non opening skylights. Would skylights need special glass? Does the roof need insulating? There will be an internal door from the dwelling Utility Room to the garage (then an internal door from the Utility Room opening in to the Kitchen). With the garage only 2m80 wide internally and 6m80 long, is the internal Utility Room/Garage door be acceptable opening in to the Garage? It was planned to be a foot away from the main car entry Garage doors. A long car may possibly prevent the internal door from opening fully? Another door (opening to the rear garden) from the garage will open outward. Are there Regs for this? I assume the Garage Floor must be lowered and sloping to the outside? With FD30 Rated fire door? With self closer? Thank you very much for your very informative forum. Quote
Neil Ashdown MAFDI Posted June 10, 2019 Report Posted June 10, 2019 Utility room to garage door should be FD30s. Check 'Building Regulations Approved Document B Dwelling Houses' https://www.planningportal.co.uk/info/200135/approved_documents/63/part_b_-_fire_safety Quote
Guest Oakey Posted June 23, 2019 Report Posted June 23, 2019 Hi please can I have some advice I want to put a wall across half my garage one side will have my motorcycle in the other will be the dwelling what do I need to clad in garage wall side in ie for regulations many thanks Quote
Tom Sutton Posted June 24, 2019 Report Posted June 24, 2019 The area that will be the dwelling needs to be separated from the garage area by a full 30 minutes separation and without knowing exactly how you intend to carry out your proposals I cannot give you a definitive response. Quote
MJF1981 Posted July 1, 2019 Report Posted July 1, 2019 Hi! Forgive me if this has already been answered but I would like to know whether the requirements for fire doors between a garage and house are for new-builds-only, or apply to all houses. I've just started renting a 1930s detached house with a garage, which has a door leading to a utility room, which has a door leading to the kitchen. Do any of the doors need to be fire doors? As this is a rented property, it would need to be a 'requirement' rather than just a 'recommendation' in order for the landlord to do it. Please can you advise? Quote
Neil Ashdown MAFDI Posted July 4, 2019 Report Posted July 4, 2019 From what you say it seems clear that area of the house could be at risk from the effects of a fire in the garage. I would consult the housing department at your local authority on this matter. Quote
Guest Mark Posted March 5, 2020 Report Posted March 5, 2020 Do I require I fire door from my kitchen to my garage if there is no car or other petrol machines or flammable liquid in there? We have the fridge and some electrical sockets but that all. thanks. Quote
AnthonyB Posted March 6, 2020 Report Posted March 6, 2020 Technically yes, the Building Regs just say garage, not garage with car/petrol/etc. If you don't have one no one is going to inspect you and do anything but expect it to be picked up if you sell the house or if you do other building works where LABC are involved. Quote
Guest GWatt Posted May 17, 2020 Report Posted May 17, 2020 Hi, I am looking to slap through into my garage and fit a FD30 door. The dwelling is detached 4 bed house with the wall being 12.5mm plasterboard dot and dabbed onto thermalite block. Unsure if the information stated previously stands for Scottish legislation, can you please advise? thanks Quote
Neil ashdown Posted May 18, 2020 Report Posted May 18, 2020 I would advise you to consult a local building regulations expert on this matter. In the meantime, this may be useful? https://www2.gov.scot/resource/buildingstandards/2016Domestic/chunks/ch03.html But check for recent updates! Quote
Guest Sue G Posted June 20, 2020 Report Posted June 20, 2020 Hi My garage is detached from the house and is adjacent to our oil tank. There is currently a door on the garage between the two which is Falling apart as it is so old. I believe that I need a fire door but what type should I buy and where would I get it from Sue from Suffolk Quote
Tom Sutton Posted June 23, 2020 Report Posted June 23, 2020 Is the garage split in two, one the garage and the other houses the oil tank, with a full sized door connecting the two. Quote
Guest Hannah Posted September 4, 2020 Report Posted September 4, 2020 Hi I've brought a new build with an internal garage and I want to use the back half if the garage for a utility room. we will be boarding it out like a room, there will be no other door to the rest of the garage. do we need the door to be a fire door if it's boarded out like part of the house. Thanks in advance Quote
Tom Sutton Posted September 6, 2020 Report Posted September 6, 2020 Providing you maintain a 30 minute separation between the garage and the rest of the house and no spills of flammable liquids or fumes in the garage can enter the house it should be satisfactory. Quote
Guest SDJ Posted October 17, 2020 Report Posted October 17, 2020 We are renovating our 1960s bungalow. We have an integral garage that is not accessible from within the bungalow. We would like to move our boiler, hot water cylinder, washing machine and tumble dryer to the rear of the garage and create internal access. The garage floor and internal floors are the same level. Will we require a 100mm step, a FD30 self closing door, both or something else? Quote
AnthonyB Posted October 19, 2020 Report Posted October 19, 2020 You will require Building Control approval for this work (it's not exempt as Building Regulations are not the same as Planning Permission & permitted development doesn't remove the requirement for Building Regulations compliance) As part of this a fire door will be required for Part B compliance, not sure about the step, will depend on the change of level and comes under Part M. Quote
Guest Neil P Posted January 1, 2021 Report Posted January 1, 2021 This forum has a good deal of information which I am grateful for, thanks to all contributors. I hope some knowledge can help with my issue with a new attached garage being added to my bungalow. The garage has no door between it and the existing building, so that’s simple; but there is an attic room to be built in the roof space above the garage (workshop) which extends over a bedroom in the bungalow. Access to the attic room is by a staircase in the garage. This gives a route for fire from the garage to travel up the stairs into the attic room. My thoughts are that the attic room would need to be fully clad with 2 layers of plasterboard for 30 min fire protection between the garage / attic room and the rest of the bungalow roof space (and bedroom below) Is this correct? Also, what material would the floor of the attic room need to be in order to give suitable FP to the floor/bedroom ceiling joists? Any ideas appreciated, thanks. Quote
AnthonyB Posted January 4, 2021 Report Posted January 4, 2021 This is subject to Building Regulations and the plans will need LABC approval - they will set conditions. It is likely that a fire door and fire resisting construction would be needed and possible additions to the fire detection system. There are a variety of ways of protecting structural elements like joists - boarding, protective pains/varnishes, Envirograf have some of the coating based solutions. Quote
Guest Bobby B Posted February 1, 2021 Report Posted February 1, 2021 We are moving house soon. The door to the garage from the kitchen has always been a standard door. Not a fire door. It's 1960/1970 house. Not sure if it ever had a fire door. We've been here since 2000 so not sure if previous occupies changed it. As we are moving do I need to put in a fire door to the garage? Quote
AnthonyB Posted February 2, 2021 Report Posted February 2, 2021 As you didn't change it yourself it could be argued that you aren't obliged to change it - however any decent survey by a purchaser is likely to pick it up so you would either need to reduce the price, get it done or, if they suspect any work has been done without Building Regulations consent ask for you to pay for building regulation indemnity insurance or latent defect insurance. Of course they may not notice at all! Quote
Deny Posted March 3, 2021 Report Posted March 3, 2021 Hi, I am trying to get my head around Building regulations and Building control, We are planning to add a door opeing in the NON load bearing wall between house and integrated garage, Bulding regulation say: door need to be FD30, 100mm difference between, and smoke seal and self closing mechanism, as per https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/485420/BR_PDF_AD_B1_2013.pdf page 30, As per Bulding contoll, Work that requires building regulation approval: Enlarging openings and removal of load-bearing walls requires Building Regulation consent. since this wall is not load bearing this work does not require bulding controll approval. Wondering if I miss anything, or things need to be considered? Quote
green-foam Posted March 4, 2021 Report Posted March 4, 2021 I believe you will find a fire door rated at 30 minutes is required, not because the wall is not load bearing, but because it leads into an integral garage. There are lots of references to it if you google "is a fire rated door required between garage and house" Quote
