Guest Guest Posted October 31, 2019 Report Posted October 31, 2019 My normal window fitter told me that he can not fit an Final Fire Exit Door for me, because this can now only be done by companies that are specially certified to do so. I have looked on line for such a company, but can't find anything. Can anyone signpost me in the right direction? Kind regards Quote
Tom Sutton Posted October 31, 2019 Report Posted October 31, 2019 He is wrong, but because it is a fire door that needs to be fitted, it has to be by a competent person (joiner) as defined by The Regulatory Reform (Fire Safety) Order 2005. If you contact the BWF or Trada they should be able to help. Check out https://www.trada.co.uk/about-us-menu-pages/links/ or https://www.bwf.org.uk/. Quote
AnthonyB Posted October 31, 2019 Report Posted October 31, 2019 If it's a final exit to the outside it often doesn't even need to be a fire resisting door wither. Quote
