Books/documents
Hi
Can someone kindly point me to the best books/documents to learn about FRA. I currently play a small part in this area as part of my job but I feel like my role will become more and more involved over the next year or so
A Colin S. Todd, A Comprehensive Guide to Fire Safety. BSI
Of course the book cannot be used isolation. The process of fire risk assessment can be broad and complex, however it is a very good starting and reference point.
Good luck
As crusher says "very good starting and reference point" bu it is only a start you will need to consider a number of courses, make yourself familiar with, many guides, many pieces of legislation, and BS EN documents.
I would also suggest you check out https://www.firesafe.org.uk it will give you an oversite of many relevant subjects which may prove useful.
