Manu_2000 Posted September 18, 2019 Report Posted September 18, 2019 Hi, I don't know if installing a 2 litre AFFF foam extinguishers plus fire blanket and smoke alarms or I need to go for a 6 litre model? The apartment has 3 bedrooms 2 bathrooms and 1 small kitchen and a sizable living room. What should I choose? Thanks very much Quote
Safelincs Posted September 21, 2019 Report Posted September 21, 2019 Hi A 2ltr foam is fine, however, with regards to the type of smoke alarms or fire alarms this depends from whether you are letting, whether this has been a renovation and so on. I would consider maybe a water mist extinguisher (maybe a 3ltr) instead of extinguisher+fire blanket. It is more versatile and a lot cleaner to clean up after. Harry Quote
AnthonyB Posted September 22, 2019 Report Posted September 22, 2019 Water mist is preferred as foam cannot be used on two of the key causes of domestic fire - Cooking oils & electrical equipment. The smallest 1.4l water mist wold be sufficient Quote
green-foam Posted September 22, 2019 Report Posted September 22, 2019 just saying.............safelincs supply a 1 litre water mist Click here Quote
Guest manu_2000 Posted September 25, 2019 Report Posted September 25, 2019 On 23/09/2019 at 00:12, green-foam said: just saying.............safelincs supply a 1 litre water mist Click here thank you everyone Quote
