fred25 Posted August 18, 2019 Report Share Posted August 18, 2019 I have just purchased a flat in a 5 storey residential block. The firex 4899 detector on the ceiling is date expired. What model now replaces this and will it fit using the old base place and connector. If base plate and connector need changing ,then who do i need to change it. Can i just replace it with a battery operated stand alone device. Quote Link to comment Share on other sites More sharing options...
Safelincs Posted August 19, 2019 Report Share Posted August 19, 2019 Hi, This Kidde smoke alarm is the official replacement Harry Quote Link to comment Share on other sites More sharing options...
fred25 Posted August 19, 2019 Author Report Share Posted August 19, 2019 Thanks, but is it a like for like replacement or will it need re-wiring ie will it fit existing base plate and is the connector the same Quote Link to comment Share on other sites More sharing options...
Safelincs Posted August 19, 2019 Report Share Posted August 19, 2019 Hi The connector and baseplate are different but the alarm will work with the rest of the existing system. The existing cable has to be inserted into the new alarm. Harry Quote Link to comment Share on other sites More sharing options...
fred25 Posted August 19, 2019 Author Report Share Posted August 19, 2019 will i need an electrician to do this work or can i do it myself if electrical supply is isolated at fusebox. Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted August 31, 2019 Report Share Posted August 31, 2019 It depends if the work is notifiable under approved Document P and under h it appears it is not, as you are using existing wiring but I would check it out with the LCBC. (building control) Quote Link to comment Share on other sites More sharing options...
green-foam Posted August 31, 2019 Report Share Posted August 31, 2019 I would suggest that as it is changing smoke detectors it has nothing to do with part p, since there is nothing new being added, I would however suggest that it has to be done by a competent person, a competent person does not have to be an electrician, but does need to know what they are doing. Quote Link to comment Share on other sites More sharing options...
