Guest George Posted July 22, 2019 Report Share Posted July 22, 2019 Hello, We live in a block of 15 flats and have a communal main front door. Currently there is a door release button next to this communal door, so we can exit the building without using a key to get out. Good for getting out in an emergency situation and for every day use too.. My question is .. would a thumbturn lock on the door also be required or is the door release button sufficient? Thanks very much, George Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted July 22, 2019 Report Share Posted July 22, 2019 I am assuming this door is locked using a magnetic lock therefore it is subject to BS 7273-4 and requires a manual release which looks like a manual call point box but coloured green. Check out the above BS for more information. Quote Link to comment Share on other sites More sharing options...
Guest George Posted July 23, 2019 Report Share Posted July 23, 2019 Thanks Tom for the suggestion. Quote Link to comment Share on other sites More sharing options...
