Guest K11fel Posted October 30, 2023 Report Posted October 30, 2023 My CO alarm let out 3 high pitched beeps and then nothing since? What could this be and do I need to be worried? Quote
green-foam Posted November 3, 2023 Report Posted November 3, 2023 Make, model, age of alarm, time (Day or night) it beeped, when did you last clean it? Please. Quote
Guest Donna Posted December 11, 2023 Report Posted December 11, 2023 Our CO2 alarm went off today advising Carbon Monoxide detected. We immediately opened all windows and turned fans on. We put our fur babies outside. We never had any symptoms and we believe it happened because hubby ran the zero turn lawnmower in the garage with the door just slightly open. The alarm has not sounded since then and it’s been 8 hours. I even tested the alarm. Is it safe? Quote
green-foam Posted December 12, 2023 Report Posted December 12, 2023 For future reference I should point out that CO2 is carbon dioxide, it is what gives certain drinks their fizz, it is also what you find in these. Carbon monoxide is written as CO I would agree with you that running an internal combustion engine within a confined space was not a good idea and was the cause of the alarm condition. Since the alarm has not sounded since, but did sound when you pressed the test button, I would say there is no more CO present. Quote
Guest Karen Posted May 21 Report Posted May 21 My smoke/ carbon monoxide detector beeped I think I heard two to three times then it stopped but I’m not sure I was asleep it’s 1 something A.M. I checked everything the kitchen and the two extra rooms to see if there was something that might of burned. I didn’t see or smell anything should I be worried. Quote
AnthonyB Posted May 22 Report Posted May 22 Refer to your manual - some of these type of alarms use different sequences of beeps for different things such as low battery or in the case of CO alarms a raised level of CO that is below the alarm threshold. Quote
green-foam Posted May 24 Report Posted May 24 Hi Karen, has the device beeped again since you asked? if not, press the test button on the device, if it operates as it should, then you have no need to worry. 🙂 Quote
Guest Stephanie Posted October 7 Report Posted October 7 Hi, my carbon monoxide detector alarm has been going off non-stop. I have the windows and doors open in my home for ventilation and the batteries in the detector don’t expire until 2025, but the detector itself is quite dusty and I don’t remember the exact date my landlord installed it and the reset button isn’t working at all. I’ve held the button for 5-10 minutes and it still continued to sound the alarm. idk what to do. can somebody please respond fast and help me? Quote
Rahel Lock Posted October 7 Report Posted October 7 Hi Stephanie as a first step I would strongly advise to evacuate your home in case of carbon monoxide being present and call Gas Emergency Services on 0800 111 999 for next steps. Please don't go back into your property until it has been checked and cleared for carbon monoxide as you can't see or smell the gas. regards Rahel Quote
