Upholstery regulations
Guest Tara Balding
I am an upholsterer and have been asked to make a loose cover for a sofa for a guest house.
could you advise me on the regulations on furniture restoration. I e. As I am not touching the upholstery and only making a loose cover, is it still my responsibility to make sure the piece meets regulations. Is there a cut off age of a piece where it doesn’t need a barrier; I have been lead to believe that anything pre 1960 doesn’t as wool, hair, down etc is naturally extinguishing and none toxic if in a blaze.
Thank you very much.
Tara
The Regulations make a distinction between the permanent cover on a piece of furniture and a loose or stretch cover. The permanent cover can be defined as the cover fitted to the furniture when it is supplied to the customer even if it is removable for cleaning or changing. Similarly, replacement covers which are supplied by the manufacturer of the furniture at a later date should be regarded as permanent covers.
The key point is that the removable cover forms only the wear/decorative cover used on the furniture and is designed by the producer/supplier of the furniture to be specific to that piece of furniture. Removable covers which are supplied with the furniture or at a later date by the producer/supplier as a replacement are regarded as permanent and must comply with Schedules 4 and 5 of the Regulations.
Loose or stretch covers, on the other hand, are removable covers which are supplied by a producer other than the manufacturer of the furniture. These are designed to be placed on top of an existing finished piece of furniture which is already fitted with a permanent cover. This distinction is made because only the manufacturer of the furniture concerned will have detailed knowledge of how it complies with the Regulations.
Loose covers for upholstered furniture must comply with Schedule 5, Part 1 of the Regulations and stretch covers must comply with Schedule 5, Part 2 of the Regulations as these are sold separately from the furniture. They also need to have a permanent label attached to them and this label may appear on the underside of the fabric. There are no display label requirements for loose and stretch covers.
Check out http://www.legislation.gov.uk/uksi/1988/1324/schedule/5/made and Fire safety of furniture and furnishings in the home - A Guide to the UK Regulations guide 2.
  • 1 year later...
Guest Jenkins
Hi Tom,
I've been reading your posts and there is wealth of information that you've provided. Very helpful indeed. Thank You.
Could you provide me with some clarity and guidance on the documentation, labelling, tests, etc required if I want to get an antique chair manufactured prior to 1950, reupholstered inside out for resale. Thank You again.
The Regulations do not apply to furniture intended for export and furniture manufactured prior to 1950. Check out https://www.firesafe.org.uk/furniture-and-furnishings-fire-safety-regulations-19881989-and-1993/ so the level of fire resistance will be up to you but I would mimic the regulations for peace of mind. You could include a label that indicated that the item was manufactured pre 1950.
  • 4 years later...
Guest Gan
Hi
I am thinking of making some new covers for some already upholstered chairs and headboards for our rent properties. The covering material we are looking to buy will be fire retardant fabrics.
Could you provide some advice and clarifications on whether any licenses or certifications are needed for the person to do the reupholstering work for rented properties in regards to the fire regulations?
Also, if during the reupholstering process, if the existing fire labels got tampered with or damaged, e.g. needed taken off and put back on again in order to carry out the work, or maybe got tears on the label when bening tampered, would the person be allowed to reattach the labels back on and restore the labels?
Thanks very much in advance.
