Guest Phil Hutchings Posted June 13, 2019 Report Posted June 13, 2019 I need to fit a fire door to our boiler room which opens onto a main activity and seating area. Could you advise what fire rating, (mins), I should fit. the room contains two gas boilers. Quote
Tom Sutton Posted June 14, 2019 Report Posted June 14, 2019 Check out https://www.oftec.org/Media/Default/DocGalleries/Technical Book Four Updates/OFTEC_TechnicalBook4_AMD_04_0413_15.pdf it should give you the fire separation you require. Quote
