Guest JeenashMis Posted November 14, 2011 Report Share Posted November 14, 2011 We have had a recent fire inspection and have been advised that we need to fit smoke seals and intumescent strips to our existing fire doors which are over 30 years old. The Building Manager has raised concerns that we should not be modifying or adapting exsiting fire doors and this may be in breach of Building Regs? Is this correct? We have been advised that intumescent strips are within the lippings of some of the existing doors and in order to fit smoke seals we will need to rout out the door edges to fit the smoke seal. Can you please advise if we can modify existing door sets? Many Thanks Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted November 14, 2011 Report Share Posted November 14, 2011 Upgrading a fire door IMO is not a material alteration therefore not subject to Building Regulation control, check out page 20 of Approved Document B (Fire Safety) or talk to your Building Control department. If a fire door has the intumescent strip under the lippings then they should not be routed as this is part of the fire door specification and the cold smoke seals should be stuck on using self adhesive seals. You can upgrade fire doors in certain situations it all depends on your Fire Risk Assessment, have you spoken to the your FR assessor and the responsible Person? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted November 14, 2011 Report Share Posted November 14, 2011 Further to my above submission check out http://www.firesafe.org.uk/fire-doors/ for more information. Quote Link to comment Share on other sites More sharing options...
Guest Jeenash Posted November 15, 2011 Report Share Posted November 15, 2011 Thanks for your advice. If we were asked to carry out the rebating into existing FD30/FD60 doors and subsequently fit the relevant seals, As a company what qualification would we need to attain and who could suggest we contact to put this into practice. Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted November 15, 2011 Report Share Posted November 15, 2011 I would suggest you contact Intumescent Fire Seals Association they should be able to help you. Quote Link to comment Share on other sites More sharing options...
